gyro wrote:There are no auger problems as far as I am aware
shadowfax wrote:Interesting notes; I am basing my comments on my friend Paul's Robur E. He's had it for about a year now and he's been dealing with the issue that the first 3 shots of his sessions are always quite sub-par; he thinks he's finally figured out that it's attributed to stale grinds in the path on the Robur E, but it's difficult to tell for sure. I've been suggesting that he start posting; maybe at some point he'll post some pictures of what his grinder looks like.
As has been discussed recently, it seems likely that in a chute full of stale grinds there's some degree of mixing, i.e. if there are 15 grams of stale grinds in the path, it's not necessarily the case that purging 15 grams of coffee through the system will yield in removing all and only those 15 grams of stale grinds.
Suffice it to say, I am suspicious that the Robur E is a low-waste solution for grinding at home. I'm curious how much better the Nino will be. It sounds like it might be significantly better, and I would really like to find out... So I ordered one, "on the cheap." More to follow.
pjones wrote:Since my Robur grinds a double (17-18grams) in 3.0 sec's, one could estimate that this is the amount of coffee it would take to displace stale with fresh coffee once that fresh coffee appeared at the chute opening. You would then have to add the weight of stale grinds already in the chute and chamber that was purged before the fresh coffee appeared at the opening. I weighed the amount of grinds left behind in the chamber as well as chute after grinding which equaled a little over 11 grams. Add these two together and you have just shy of 30 grams.
michaelbenis wrote:Ah so it doesn't actually break up any beans around it, just pushed them in whole?
gyro wrote:Thanks for doing this, I think thats quite good to know that there is at least a fairly good purge of the system by a sacrificial seasoning shot. Although the densities are different, if it purged well both ways (ie coffee to rice, and vv) then I don't think it an unreasonable assumption that with equal densities it should do also.
Had a few drinks last night so my head is not as clear as it should be, but if it completely purges the rice, or coffee, in 3 secs, then isn't the total 'stale' coffee going to be around 18 grams as that already counts the weight in the chute (by virtue of clearing it). In other words, if everything has changed from white to brown in 3 secs, then 18 grams of residual grounds? This would tally with my effort (albeit a little flawed) that resulted in 14 grams residual coffee by simply running it until the hopper was empty. I might be missing something here though as I am a bit hazy
shadowfax wrote:I think we should figure out a standard procedure for how to quantify how much rice purging it takes to get all (or almost all) of the coffee out the chute
