by cremadelacrema on Wed Mar 16, 2011 1:18 am
If it just won't budge, and you've exhausted all other options, put the collar in a vise. I was in the same spot as you this week. I tried a heat gun, blow torch, huge pipe wrench, strap wrench, mallet, and even penetrating oil (even though that's a no-no). Finally, I took off the doser, turned it upside down, gripped the collar in a vise, and twisted as hard as I could. I put the pipe wrench in the spot where the doser attaches and used it as a lever. It took a good 200 pounds of pressure to break it loose!
Afterwards, I chased the threads with a wire brush attachment on a dremel and a chasing file. The threads on these are surprisingly fragile! Be careful. Contrary to some opinions here, I've had good luck using a razor blade, pin, or similar tool to clean the threads without damaging anything. Look for cross-threading, broken or folded-over threads. That's what did it on this grinder; someone carelessly took it apart, knocked the threads on something, then forced it back into position.
Consider covering your vise jaws with rubber to keep from damaging the collar. At this point, a few scratches might be the least of your worries though!
