another_jim wrote:It is actually less of a problem for the Robur, since it runs at 300 RPM, not the 1600 to 1800 that is common to most grinders.
Is this correct? Presumably the same work is done breaking 100g beans, be it at 300 or 1600RPM. A higher RPM may have the benefit of more cooling due to higher air flow. A low RPM that grinds very quickly releases all the heat in a short interval.
The efficiency of the burrs in turning beans to powder will affect the total heat due to friction between the incomplete grind and the burr.
A more powerful motor has more torque at the same RPM and is thus less subject to overload. A slower motor has more torque at the same power. A reduction gear increases torque by reducing RPM, but also reduces overall power due to friction losses in the gearset. hp = t * f / 5252.
