Mazzer Mini Electronic grind quality vs Super Jolly
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by markl on Thu Dec 13, 2007 11:59 am
Hi All
I just upgraded to a Mazzer Mini Electronic. I am very pleased thus far and I can't believe that it has taken me so long to replace my old Solis Maestro! I struggled with grind consistency and I couldn't grind fine enough for certain blends even after doing the modification. Anyway, I was wondering, can I assume that the grind quality that I am getting is the same as that from the Super Jolly? The burrs are exactly the same size (64mm). It's obviously a slower grinder, given it's weaker motor, but this shouldn't effect the grind quality, should it? Or have I missed something?
An interesting thing, that I noted, was that with 220V/50hz AC(which is what we have) the motor does 1400rpm as opposed to 1600rpm on a 110V/60hz AC circuit, which would reduce the amount of heat transferred to the coffee during grinding.
Chrs
Mark
markl
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by moccamaniac on Fri Dec 14, 2007 1:32 am
Hi Mark,
I upgraded on the Mazzer too and only wish I would have done that earlier. That grinder is the perfect fit for my needs, grinds so much better and neater, and in the polished version I ordered it, pairs up beautiful to my machine. Since the burrs and the motor speed are exactly the same, grind quality and grind speed should be exactly the same on a Super Jolly. The stronger motor makes the SJ not faster, but more robust for commercial use. For home use I prefer the advantages that a doserless design provides me. Very happy with my new grinder, fast enough for my (home) needs and certainly not producing too much heat.
Ciao, Tom
moccamaniac
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by HB on Fri Dec 14, 2007 1:39 am
moccamaniac wrote:The stronger motor makes the SJ not faster, but more robust for commercial use.
Although they both have 64mm burrs, the Super Jolly is actually much, much faster than the Mini E. When I first switched to the Super Jolly for the Titan Grinder Project, I constantly overshot the target dosage. The "Duranium" burrs were even faster:
Duranium burrs for Mazzer Super Jolly grinder
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by moccamaniac on Fri Dec 14, 2007 11:13 am
HB wrote:Although they both have 64mm burrs, the Super Jolly is actually much, much faster than the Mini E.
Both have exactly the same burrs, both have exactly the same 1400 rpm at 50 Hz, but much, much faster grind on the SJ: amazing! :shock: I'm not the greatest in physics, but do I miss here something? A different design of the burrs like those "Duranium" burrs can clearly make a difference, but with same burrs and same rpm? Please explain!
Ciao, Tom
EDIT:
OK, the "antistatic-fence" on the Mini E could take some speed, but who cares that much about speed in a home setting anyway? Grind quality should really be the same.
moccamaniac
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by HB on Fri Dec 14, 2007 11:31 am
moccamaniac wrote:OK, the "antistatic-fence" on the Mini E could take some speed, but who cares that much about speed in a home setting anyway?
That could be it, I don't know. The difference in speed is unmistakable.
moccamaniac wrote:Grind quality should really be the same.
Although I haven't carefully compared them side-by-side, I did spend a couple months using both. My impression is that they're not the same grind quality. Maybe it's the compaction of the grounds caused by the doserless design, maybe it's my imagination, but I remember thinking the Super Jolly's pours were more consistent. I welcome the opinions of those who have compared them side-by-side.
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by markl on Fri Dec 14, 2007 11:45 am
Thanks for the feedback guys.
I don't know much about electronics myself but surely the beans provide some level of resistance to the motor when they are being ground up? Perhaps this is negligible but perhaps the 350watt motor of the Super Jolly doesn't slow down as much, in the "face" of this resistance, compared to the 250watt motor of the Mini Electronic...or something?! Or maybe I don't know what I'm talking about!? :) I'd just like to understand why there is this dramatic difference in speed.
Chrs
Mark
markl
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by jesawdy on Fri Dec 14, 2007 12:33 pm
Dan, I think you have a Mini-E at the moment, no? The SJ grinds a double in about 8-10 seconds. How long for the Mini-E?
Jeff Sawdy
jesawdy
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by HB on Fri Dec 14, 2007 1:11 pm
OK, I just measured: It ground 15 grams in 20 seconds. Note the grind setting and coffee bean hardness affects the speed; it's currently about 5 notches finer than the factory "start here" setting. The estimate that the Super Jolly is approximately twice as fast sounds right to me.
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by cannonfodder on Fri Dec 14, 2007 7:58 pm
Here is a grind test I did to measure my fresh from the box SJ for the titan grinder project.
[gvideo]http://video.google.com/videoplay?docid=208103548712483624[/gvideo]
cannonfodder
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by HB on Sat Dec 22, 2007 9:53 pm
UPDATE: Andy pointed out that the Mazzer Mini Electronic and Mazzer Super Jolly have the same diameter burrs, but they are not the same part numbers. According to espressoparts.com, the burrs are reference numbers 182D for the Jolly and 189D for the Mini E. I assume (*) the speed difference is attributable to a difference in the burrs' cutting angle.
(*) D'oh! I just returned Lino's Super Jolly this past Friday; I could have compared them side-by-side...
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by WilsonHines on Sun Dec 23, 2007 2:53 pm
markl wrote:Hi All
STATEMENT: I am very pleased thus far and I can't believe that it has taken me so long to replace my old Solis Maestro! I struggled with grind consistency and I couldn't grind fine enough for certain blends even after doing the modification.
QUESTION: It's obviously a slower grinder, given it's weaker motor, but this shouldn't effect the grind quality, should it? Or have I missed something?
STATEMENT: An interesting thing, that I noted, was that with 220V/50hz AC(which is what we have) the motor does 1400rpm as opposed to 1600rpm on a 110V/60hz AC circuit, which would reduce the amount of heat transferred to the coffee during grinding.
Chrs
Mark
Hey Chris,
I just upgraded from a Kitchenaid Pro Line last night. I too am AMAZED at the difference. Actually, my KA PL lasted one single day before I hit a solid VISIBLE wall of limitation.
Here is my problem, but it is a good "problem," I guess. I was trained on a Robur and the two bars I have had experience on had Roburs and Jollys. Look, I find myself waiting on the Mazzer. Heck, I waited on the Jolly, but I am really waiting on the Mazzer. It is just sooo sllloooowww compared to the Robur. I find the grind quality to be right there with the Jolly, no question on that idea.
But, this means one thing for me and my espresso setup: There will be a Robur in my house eventually and this mini will be subjected to Decaf work. Which is OK, my Decaf volume may just beat allot of coffee bar volumes, "per capita." For example, this morning I had a guest over, my wife and both of my girls. I pulled four doubles on decaf for the girls and one capp for both of them. That is five pulls. I pulled five regular shots for my guest and he had a capp. My wife had two doubles and a capp. I had five doubles and capp. When I sit at a bar for a while, I hardly ever see that decaf machine work.
WilsonHines
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by markl on Sun Dec 23, 2007 6:24 pm
Dan,
That's very interesting! Now I'm curious...I wonder if you could install the Super Jolly burrs in the Mini Electronic? Would those holes line up? :) You'd effectively have a doserless Super Jolly, albeit with a weaker motor that would need more recovery time...
@Wilson, For me, speed is not a huge issue as I usually just make doubles for myself and the occasional cappa's for friends that visit.
Chrs
Mark
markl
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by Bill2 on Sun Dec 23, 2007 8:10 pm
I also wonder if the parts are interchangeable. I had always assumed that they were the same part, as I'd never seen a 64mm Mini-E burr set on any online catalog. eg. Take espressoparts.com mentioned above - They have a 58mm burr set listed for the Mini and a 64mm burr set listed for the Super Jolly, but no 64mm set listed for the Mini-E. So I had always assumed that when I came to replace my Mini-E burrs that I'd have to buy the Super Jolly part.
Bill2
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by RapidCoffee on Mon Dec 24, 2007 3:12 am
WilsonHines wrote:Here is my problem, but it is a good "problem," I guess. I was trained on a Robur and the two bars I have had experience on had Roburs and Jollys. Look, I find myself waiting on the Mazzer. Heck, I waited on the Jolly, but I am really waiting on the Mazzer. It is just sooo sllloooowww compared to the Robur. I find the grind quality to be right there with the Jolly, no question on that idea.
Your comment about waiting on the SJ does not mesh with my experience. In the Titan Grinder testing, I found the Robur to be only slightly faster than the SJ:
Robur: ground 20.0g in 8-9 seconds, yielding 19.6g grinds
MXK: ground 20.0g in 20-22 seconds, yielding 19.2g grinds
Super Jolly: ground 20.0g in 10-11 seconds, yielding 20.0g grinds
I'd love to have a Robur for the grind quality and forgiveness, but you'd probably be better off with a Major if speed was the main issue. In general, conical grinders grind more slowly, due to slower rpms and a longer grinding path.
John
RapidCoffee
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by Sedi on Mon Dec 24, 2007 4:01 am
RapidCoffee wrote:Your comment about waiting on the SJ does not mesh with my experience. In the Titan Grinder testing, I found the Robur to be only slightly faster than the SJ.
What kind of Robur?
I guess there is a noticeable difference in grinding speed between the 110v Robur with its 71mm burrs and the 3 phase 220v Robur with its 83mm burrs. Both spin at 500rpm. Note the difference in the picture down to the right:
http://www.espressoparts.com/product/MAZZER_220ROBUR/
Are there cafes, or anyone else using this second kind in the U.S?
If so, maybe this settles the difference in your observations?
Sedi
Link to "Mazzer Mini Electronic grind quality vs Super Jolly"by RapidCoffee on Mon Dec 24, 2007 4:11 am
Sedi wrote:I guess there is a noticeable difference in grinding speed between the 110v Robur with its 71mm burrs and the 3 phase 220v Robur with its 83mm burrs.
Good point. We tested the 110V version.
John
RapidCoffee
Return to Grinders
