shadowfax wrote:Take off the hopper, set down a towel, and turn the grinder (unplugged!) over on the towel so it's upside down. take off the legs (they unscrew) and, if it's there, the big flathead screw between the front legs. Now you can set the grinder on its side, holding the bottom plate to the body as you do, and then carefully pull the bottom plate away, careful not to pull any wires apart. Have a look for yourself. Any apparent damage to the wiring? Anything obviously wrong? If you have a camera, snap some photos.
It's fairly unlikely that the motor is shot, and more likely that it's a wiring problem, or a control problem.
Strange thing happened, I took the bottom of the grinder off, didnt see any wiring problems, but it still would not run. Then the grinder would run while lying on its side but not when it was upright. Somehow when I put it back together it magically started working. Sound like a short?
