by spyderx on Sat Oct 09, 2010 12:51 pm
This doesn't sound right. I have this grinder and am about 2 "notches" finer from the 'start here' arrow. I dose 20g in a triple basket using black cat organic (normally). This gives me about a 1.5oz shot in 25 secs with my Salvatore.
My "start here" arrow is around 7. It will vary by grinder.
One thing you should try is to empty the beans out of the grinder, set the grinder coarser and make sure all the coffee is out of it, then, while the grinder is running, VERY SLOWLY turn the grinder setting (use the notches as the index, NOT THE NUMBERS) finer until you hear a VERY slight metal on metal ticking sound (this is the burrs touching). Turn off the grinder immediately. DO NOT go any further, that is your finest setting, mark it with a sharpie pen on the carrier. Back it off coarser and start somewhere between that setting and the "start here" setting on the grinder.
Remember, only adjust finer while the grinder is running.
The adjustments on this grinder are not by "numbers" they are by the notches on the burr carrier, very, very slight adjustments make a big difference.
