www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
Mazzer Mini doser removal....hex head screw size
Postby mixedup on Wed Dec 29, 2010 8:22 pm
First off, i've read the other threads regarding this....but I'm hoping someone can tell me what size socket I need to remove the doser. Mine has tiny hex-head screws....I've got a 4mm socket and it's too small....but it also looks smaller than a 5mm, so I'm guessing it's a 4.5mm??? Seems like an odd size....
mixedup
Postby Phaelon56 on Wed Dec 29, 2010 9:43 pm
Are you sure your 4 mm is really a 4 mm? I use a 4 mm on my Mazzer hex screws regularly - no problems.
Phaelon56
Postby erics on Wed Dec 29, 2010 10:04 pm
I think I know the tiny hex head screws you're talking about. Although I'm referencing a Mazzer Mini-E, a 4 mm is too small (for mine also), a 5 mm is too large, but a 3/16" fits OK - not perfect, but OK. I just used it tonight when tidying up a little.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby mixedup on Thu Dec 30, 2010 8:15 pm
thanks! 3/16 did the trick. I'm still guessing it's a 4.5mm, but that size socket isn't easy to find, so this works fine!
mixedup
Return to Grinders
