13thfloorelevators wrote:it can indeed be simple converted. u need a capacitor of course and the power will be limited. just google after steinmetz!
my faema fp grinder has the same modification and ive seen it within a few grinders....so should really be no problem, except for the limited power (but they are overpowered anyway...)
What you are apparently advocating is ill advised. It's possible to start a three phase motor on single phase by adding capacitance to two legs and changing the starting capacitor. This is a so called "static phase converter". The additional capacitors, charge and discharge on startup to start the motor. But while relatively inexpensive, this is inefficient, causes the motor to run hot and only at partial power. Not to mention that choosing the correct size capacitors varies with the motor size and is largely trial and error. If your motor is run under full load it may well burn out due to the poor quality power that will create a lot of heat in the motor windings.
On the other hand, the more expensive variable frequency drives or (better quality) rotary phase converters work fine if you can find an affordable one. The best luck is if your motor turns out to be wound (wired) at the factory so that it can also work properly on single phase power. If so, then it's simple and inexpensive to change a few wire connections and run such a motor on single phase power.
