by fronesis on Fri Apr 17, 2009 8:21 am
Scott - let me try to dig out the old video camera and see what I can produce.
Sam - First, the painting project wasn't all that hard, just time-consuming. The better you do the prep work, the better it comes out. I was in a rush and only 2 coats of paint (after 2 of primer), and I think I'd do 4 thin coats if I was to do it again. And you need to have a good ventilated place outdoors to do the painting, which in my case wasn't easy to find.
As for the throat: I, too, started by putting the tamp in there, but that looked like a bad idea long term to me (hex bolt). Right now I have the bottom collar of the standard hopper; it disconnects from the hopper with just one screw. I just open the little trap door to put in the beans, then close when I grind. This works fairly well except: A) it won't hold many beans this way, and B) the opening into that collar is very small, so it's easy to spill beans.
I think some folks have fashioned little PVC funnel setups, and I'd love to hear recommendations or see links to those solutions. I don't have much space to clear the cabinets, but I'd love something a little wider and a little larger.
