Mazzer Major E Thread Lubricant
- Col_Potter
Just picked up a "year" old Mazzer Major E off Craigslist. Fairly good shape, just some cosmetic nicks in the paint and needing a bit of cleanup. Just took the burr carrier out to check out the burrs and noticed the lube on the threads is pretty crusty. Anyone know what type of lubricant is used on these?
The Colonel
- Randy G.
I have been using "Ultra-Lube" brand, White Lithium Grease (#10307). It's plant-based, non-toxic, and biodegradable. Its smoothness and consistency reminds me of Campagnolo grease. I get it at Lowe's. The trick is to get ALL the old lube out of both the male and female threads (more time consuming than it sounds). A good grease-cutting cleaner solvent and a microfiber rag works. Then work the smallest amount of grease you can into the threads of both, remove the springs, and screw the carrier in and remove it, wipe off excess and repeat, adding a bit of grease if necessary.
- pizzaman383
- Supporter ❤
What's the benefit of the thread lubricant?
Curtis
LMWDP #551
LMWDP #551
- cannonfodder
Lubricated threads.
The thread pitch is very, very fine. A drop of lube will help keep them from binding up but too much will attract coffee dust and turn into grout. It only takes a Q-tip sized drop to lube them. Just put a drop on the frame towards the top and screw the upper carrier on. It will spread out as you screw the carrier in.
- Col_Potter (original poster)
Thanks Randy, forgot to say so awhile back.Randy G. wrote:I have been using "Ultra-Lube" brand, White Lithium Grease (#10307). It's plant-based, non-toxic, and biodegradable. Its smoothness and consistency reminds me of Campagnolo grease. I get it at Lowe's. The trick is to get ALL the old lube out of both the male and female threads (more time consuming than it sounds). A good grease-cutting cleaner solvent and a microfiber rag works. Then work the smallest amount of grease you can into the threads of both, remove the springs, and screw the carrier in and remove it, wipe off excess and repeat, adding a bit of grease if necessary.
The Colonel
