Manual grinder bug - Pharos or HG One? - Page 5
This is consistent with the 4 seconds or so that a 500 rpm big conical grinder takes, which gives 33 1/3 revolutions.
--Matt
--Matt
- weebit_nutty
I recall HG One stating this fact--burrs and crank wheel are 1:1.
- FotonDrv
I just went and marked the burr and turned the crank. 1:1 is whats happening. Now to measure the inch pounds or foot pounds of effort to turn the crank. Breaking out the torque wrench soon
Does anyone use their HG One without the crank arm? I assume that the handle attaches where the crank arm is bolted near the rim of the flywheel. Harder to turn, but higher speed...
I removed the lever on mine this afternoon. Doesn't seem to need much more effort to me, but I've only done two grinds without the lever and not with very lightly roasted beans.
Yes, the handle does go where the outer lever bolt was.
http://hg-one.com/the-hg-one-grinder/ca ... dle-lever/
Not sure about those instructions. The centre bolt is longer than the outer bolt. When the lever is removed it wouldn't screw in far enough to fix the flywheel adequately, so I replaced it with the shorter outer bolt.
- FotonDrv
I have not tried it since it has been broken in, and since I am a puny geek type (read old and disabled with shrapnel in the right shoulder) maybe I might end up putting it back in place
- wrz0170
I use mine as intended. My right shoulder is bum due to dislocations and surgery and it's not even a strain. Oddly enough, I find it enjoyable.
- FotonDrv
Therapy...
Off topic, I noticed your new profile pic. Are you a fan of Nosferatu and Max Schreck? It's one of my favorite films of all time. The cinematic counterpart to the HG1, so to speak.wrz0170 wrote:I use mine as intended. My right shoulder is bum due to dislocations and surgery and it's not even a strain. Oddly enough, I find it enjoyable.
