What I ordered:
What I got:
July 12, 2011
Bronze bearing before cutting in half and machining the inside for a tight fit to the lower burr. I was going for an interference fit, but... that's what Loctite is for.
Lower burr fit to bronze bearing:
Tomorrow: Threading the outside of the bronze bearing
July 13, 2011
Trued the bronze bearing to the lower burr holder outer circumference. I don't know if this will be precise enough-- I don't know if the burrs are cut truly concentric to the circumference or whether the mounting holes are the reference point. I also don't know what sort of tolerances I should be working at.
Bronze bearing true to burr:
Then threaded the bearing. At first I thought of doing 56 TPI, but then decided to do 22 TPI which won't allow as much leeway in dialing in the grinder, but seemed close to 1mm threads that someone mentioned the Mazzer Mini uses.
Here's a video of cutting threads on a very old lathe using lard:
http://www.youtube.com/watch?v=f5CBtp4VuqU
Next step is to layout the shaft which will be 3/4" stainless turned down to 5/8" for part of it to slip into the bearings. The bottom will be slotted to hold the lower burr and also threaded to keep the burr from dropping off. Inside thread as well to be used for centering the inside burr to the outside burr. Top will be slotted and threaded to hold a hand crank for use in off the grid mode.
