Maintenance about HG one
The super lube of gear box, is it need to change the lubricant every year?
- Bikeminded
You may contact Paul/Craig on that, but I think I'd just follow their recommendations. It appears pretty simple. No harm in popping off the cover to inspect the grease as well.
http://hg-one.com/the-hg-one-grinder/ca ... ter-gears/
Ultimately, probably would depend on your duty cycle of the grinder.
- dergitarrist
I don't think you need to do this every year, to be honest. But yeah, it depends on use. I'll probably consider opening mine up in 3-4 years...
LMWDP #324
- baldheadracing
HG Website suggests twice a year.
-http://hg-one.com/the-hg-one-grinder/ca ... intenance/we do suggest a bi-annual servicing of a couple of parts ...
Cleaning and servicing the miter gears
Cleaning and servicing the burr mount
Bi-annual means every two years. Semi-annual means twice a year.
What ever Bi-annual means. The guys at HG-One mean TWICE a year servicing.
"Your general maintenance routine is equally simple. Even for the most fastidious, the HG one grinder only requires a twice yearly check up. With just two parts that require servicing, and with each routine taking only twenty minutes, you can spend your time doing more important things in your already busy life"
- baldheadracing
bi-annual = twice a year (twice within a time period that is a year long, to be pedantic)
biennual = once every two years
In any case, no doubt they are being safe. Usage and the 'hardness' of the beans being ground will vary widely.
Oops. You are correct, sorry!baldheadracing wrote: bi-annual = twice a year (twice within a time period that is a year long, to be pedantic)
My question is what brand or kind of grease does one use to service the grinder?
- FotonDrv
"Superlube" I believe is the brand name that they use as per Craig.
