by mhmercer on Sat Nov 12, 2011 11:33 pm
I experienced the lock-up today. The problem seems to be in the momentary switch shaft's movement. After checking everything else, I removed the portafilter holder, then tried to cycle the grinder by hand. Nothing. Looking further, I noticed that the momentary switch's shaft was stuck, about three-fourths of the way through its travel. After cleaning the shaft with a paper towel and water, the shaft moved freely. Problem solved. This seems to me to be a design flaw. If coffee falling onto the shaft causes grinder failure, the shaft should be protected; a rubber "bib" would do that.
Marshal
