Mahlkonig K30 jamming - Page 5
Well that label makes much better sense. Motor shop to see what is wrong with it is the best bet.
Sorry to bother, but I'm not really getting the whole thing here and I'm considering the K30 for myself.
This is due to the motor with light roast? Are they to hard to be ground for new burrs that need to be seasoned? What about the "one burr at a time" solution? I don't really get what that means.
Sorry for silly questions.
Thank you.
Thank you.
- uscfroadie
The lighter the roast, the harder the bean, thus takes more power to grind. The one burr at a time means install one of the two burrs (upper or lower) with one of the older burrs (upper or lower) .Tia93 wrote:Sorry to bother, but I'm not really getting the whole thing here and I'm considering the K30 for myself.
Thank you.
Keep in mind this is not the norm, otherwise every person that bought a K30 would be posting that it can't grind light roasts, which is not the case as I have no trouble on mine.
It would be nice to know how this grinder was treated in the first 82,000 shots of its life.
Agree.OldNuc wrote:Motor shop to see what is wrong with it is the best bet.
Merle
Either the capacitance value is too low and/or there are failed windings in the motor.
Didin't really thought of that, thank you.uscfroadie wrote:The lighter the roast, the harder the bean, thus takes more power to grind. The one burr at a time means install one of the two burrs (upper or lower) with one of the older burrs (upper or lower) .
I was pretty sure it was not common (I've read really a few if any complaining about the K30), but thank you for clearing it out.
How would the thermal protection work?OldNuc wrote:Either the capacitance value is too low and/or there are failed windings in the motor.
Hey, the grinder you have there has no US setup. So it will lack power to grind hard, lighter posted beans. Do you know where the grinder was used? Especially new burrs require higher torque since they are more aggressive and faster due to (still) sharp teeth...new burrs together with an European setup motor and light beans cause the grinder to jam. The requirements for the motor setups have changed a lot since 2007. Back then nobody was using light roast beans for Espresso.
So you need to consider this before blaming the K30 !
- JohnB.
The Euro K30 in question actually has a higher power rating (580w) then the U.S. version (545w).
LMWDP 267
- Bluecold
No other old commercial grinder has issues with newfangled light roast for espresso. Not even the spanish discount brands.Flipper wrote:The requirements for the motor setups have changed a lot since 2007. Back then nobody was using light roast beans for Espresso.
LMWDP #232
A thermal switch in the windings is mostly a bad joke.
I don't think the OP is/was blaming the grinder and the OP is located in Glasgow. I think he is looking for a fix to the problem.
