Mahlkönig K30 ES/Vario v. ProM v. (Baratza) VARIO Home
Postby zin1953 on Tue Nov 24, 2009 10:17 pm
So, yes, Mahlkönig has introduced the "Pro M" in Europe (or, at least, it's on the German ".de" website; not on the US ".com" website). English language content is available, including .PDF files, via the German site.
A couple of things, just for the sake of discussion, to take note of . . . or not, as per Mahlkönig's own information.
Grinding Disc Descriptions:
VARIO = 54 mm ceramic
ProM = 65 mm "tool steel"
K30 ES/Vario = 65 mm "MAHLKÖNIG-special tool steel: Special alloy with a better resistance against abrasion for longer lifetime"
(Approx.) Grinding Speed:
VARIO = 1.6 grams/second
ProM = 2.3 grams/second
K30 ES/Vario = 3.5-4.8 grams/second
Maximum Recommended Daily Grinding Capacity:
• With the VARIO you should not grind more than 50 double shots per day.
• With the ProM you should not grind more than 150 double shots of espresso per day.
With the K30:
• Single-phase operation 200-240V: 4 seconds grinding / 16 seconds pause (= 3 double-shots per minute)
• Single-phase operation 100-120V: 4 seconds grinding / 26 seconds pause (= 2 double-shot per minute)
• Three-phase operation: 4 seconds grinding / 6 seconds pause (6 double-shots per minute)
FWIW . . . .
zin1953
Postby akallio on Wed Nov 25, 2009 6:48 am
One more: ProM has belt drive, but if my memory serves right K30 has direct drive.
akallio
Postby Richard on Sat Dec 19, 2009 8:42 pm
zin1953 wrote:So, yes, Mahlkönig has introduced the "Pro M" . . .
Has there yet been any ProM sighting in the wild, i.e., any hands-on knowledge or experience?
Richard J. Wyble
Richard
Postby Nik on Sun Dec 20, 2009 12:57 pm
I spoke with the local dealer on Friday and he stated that they would be available next week...before Christmas. He passed this information on from Mahlkonig. He stated they are still at the dock awaiting approval.
I wouldn't bet on it!
Nik
Postby Richard on Sun Dec 20, 2009 1:40 pm
I have all sort of questions about the ProM. If those 65mm burs are the same as those in the K30, it might be a viable replacement for my K30, depending on several other factors.
There have been WAF issues with the K30, and I must say the Cremina sitting next to it looks like a small mantis ready to pounce on an oversized R2-D2. The design and dimensions of the ProM could address several issues. :roll:
Richard J. Wyble
Richard
Postby Nik on Sun Dec 20, 2009 2:46 pm
Just the opposite here with the wife. I think she would pitch me out before I could take the K30 away. The custom hopper brought the height of it down to around 16 inches which makes it much more acceptable size wise.
I am optimistic about the Pro M as long as the construction is solid. I am not looking for it to replace my K30 but as a second grinder to use for drip or different espressos.
Hope it performs well.
Nik
Postby Mark08859 on Sun Dec 20, 2009 4:52 pm
Richard wrote:There have been WAF issues with the K30, and I must say the Cremina sitting next to it looks like a small mantis ready to pounce on an oversized R2-D2.
WAF = ???? Thanks.
Mark08859
Postby da gino on Sun Dec 20, 2009 5:07 pm
WAF = Wife acceptance factor
da gino
Postby yellow_speedster on Wed Dec 30, 2009 6:18 pm
Richard wrote:Has there yet been any ProM sighting in the wild, i.e., any hands-on knowledge or experience?
Yep, just got one yesterday. It is a very nice grinder, very fluffy grinds and really no static issues at all.
The grinder starts automatic after inserting the portafilter and gives you a single portion. Tipping the start button once and then insert will give a double portion.
I did not have a lot of time playing with the grinder but first the impression is great.
Here are some pictures I made.
Frank
yellow_speedster
Postby portamento on Thu Dec 31, 2009 7:43 pm
Beautiful -- thanks for the update, Frank. Have you taken any pictures of the burrs?
How is the ProM priced?
portamento
Next
Return to Grinders
