Mahlkonig EK43 Barista - Page 2
I have to say the EK43s all look like they could grind meat too.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
Alex
- jcw5002
Quick, someone measure how tall it is!FotonDrv wrote:That appears to be back to back with a full sized EK, is that correct? A few inches difference.
Is this this final production version, or still a prototype? It doesn't look much different than the one marked "Prototype" on the marketing photo.
- Terranova (original poster)
- Supporter ❤
Here is a little clip
and another one in a better quality
Not much info yet, but interested in exactly how the various settings work. I know they don't care too much about nerds buying for the home, but I hope they will make more limited edition mini-EKs, because I can't see this being anything but expensive. And pre-weighing doses is not that big of a deal in a home setting. The new knife set will probably also fit classik EK unless made for different speeds only?
- jcw5002
There are some more details in this high res photo that Prima Coffee posted on twitter. If you zoom in you can read the card:
EK 43 Barista - All-round grinding solution built for the best!
+ Universal Motor Adjust
able to 450-1800 rpm at any time by large wheel at the side
+ New double-threaded adjustment wheel for general adjustment from espresso fine
to french press course and secondary fine tuning.
+ New portafilter rest and spout - easy to disassemble for easy cleaning and
individual setting
Source:
individual setting
Source:
- CrabRangoon
I much prefer the appearance of the standard EK to this one. Though I much prefer the sight of an EK with your dosing tool atop itTerranova wrote:Here is a little clip...
If the final production version of the EK43B resembles what we see here, count me out - I'll take the original over this, even if I need to swap out a Santos lower case myself.
LMWDP #505
- Possepat
Another grinder that will not fit under my cupboards
"Do what you want, you're gonna do it anyways!" - My father
LMWDP #365
LMWDP #365
- Supporter ❤
