Mahlgut grinder (Kind of Pharos-ish) - Page 27
- spressomon
The copper and stainless variants are extra gorgeous. Th SS Grist MG-1 weighs about 4 pounds more than my aluminum MG-1 (6lb 15oz versus 11lbs for the SS version). I have not seen a price on either the copper or the stainless. Me likes the polished stainless version!
No Espresso = Depresso
Static also has to do with the beans your using. For example if you use a malabar they are well known for there "static-ness" so maybe there is your problem with the static issue?buddalouie wrote:I have tried excessive spritzing and i still get static. It seems to really stick to the metal on the lower burr carrier, if I am naming the part correctly. Basically the polished metal directly under the burrs. Is there anything I can do there to make it less clingy, aside from spritzing the beans?
I use the MG-1 with 3 sprays of water on 18 grams of beans. Seems to be working just fine. I leave the bean opening open on the MG-1 so water can evaporate easily if it is in the grinding chamber.
- dominico
With regards to tightening of the adjustment collar, does it concern anyone that the set screw is bare metal against the thread?
https://bit.ly/3N1bhPR
Good question there. If it's aluminium against stainless steel, I figure it'd be fine. Other than that, I am not so sure. Does it have to be tight to prevent slippage?
- spressomon
Before I made the decision to purchase my Grist MG-1 I posed the same question to Michael at Mahlgut. He said there was zero issue regarding the degradation of the threads apart of repeatedly tightening the lock-set thumb screw (hand tight is all that is required).dominico wrote:With regards to tightening of the adjustment collar, does it concern anyone that the set screw is bare metal against the thread?
After 4-1/2 months of use, with a variety of different beans requiring adjustment of the grind setting at least weekly if not a little sooner, frequent disassembly/reassembly, there has been no degradation to the burr shaft threads. And the grind setting/thumbscrew has never errantly slipped from it position.
- spressomon
The only little minor quibble I can muster about the Grist MG-1: The top 3 thumbscrews tend to loosen on their own. Its not a big deal and the grinder's torsional rigidity doesn't seem to suffer but threaded fasteners are supposed be tight .
So I finally ordered some suitably sized stainless Belleville style spring washers from McMaster (part # 96475K216). Problem, as slight as it was, has been solved .
If there is room to put in a delrin or lead pellet. That would solve the problem. Lead is the classic solution, but probably harder to come by then it used to be. Copper might be OK too. Or something from this page:dominico wrote:With regards to tightening of the adjustment collar, does it concern anyone that the set screw is bare metal against the thread?
http://www.mcmaster.com/#set-screws/=112k6i8
Ira
