The introduction to the article says it all:
Weiss Distribution Technique wrote:Many grinders inflict clumps, static, and uneven distribution upon the hapless home barista, keeping them from reaching their goal of extraordinary espresso. We can hope that these design flaws will eventually be addressed in home grinders. But until then, there is a simple, inexpensive solution to grinder problems: the Weiss Distribution Technique, or WDT.
In my experience, the Macap M5 (known as the M4 in the U.S.) doesn't need the WDT treatment, if the barista corrects distribution issues while dosing by thwack thwack thwacking the doser handle. Keep in mind that clumps are not the problem per se, it's unevenness of the distribution. So, for example, a grinder that slowly extrudes coffee in fits and spurts (e.g., Rancilio Rocky doserless) will benefit more from the WDT "correction" than a grinder that spits out a constant stream of tiny pebbles (e.g., the Mazzer Mini E).
If you employ the WDT, I recommend the method John describes, i.e., directly in the portafilter basket. To combine weighing and distribution correction, you can remove the basket retainer clip from the portafilter as demonstrated in the
Stockfleths Move for Dummies.
