by ira on Wed May 12, 2010 8:46 pm
Having installed the update on my M4D, I'd have to highly recommend you do it. There is one thing you might try before that though.
Remove the hopper and the plastic gear ring, remove the 2 screws holding the big button and display. Carefully set the display to the right.
Remove the single screw at the back holding the chute cover and remove the chute cover.
If your chute has a splitter that divides it into upper and lower chutes, proceed, otherwise button it back up. If it has a little fork thing pointing down you already have the new version.
Remove the 2 screws holding the chute in place and carefully pry out the chute. On mine it was really tight and it took a bit of careful prying and wiggling to get it out and back in. Remove the splitter, it just slides out the end.
Then put it back together without the splitter. The static might be worse, but the clumping will likely be almost gone.
Ira
