by cafeIKE on Tue Apr 14, 2009 2:25 pm
It's not that I have to be right. Statements that are patently wrong must not go unchallenged. It's how we evolve reasonable recommendations.
Following the instructions in Paragraph 5 to the letter may result in over heating the grinder. This is good advice? There should definitely be a duty cycle warning of 30s on / 120s off included for grinders with a stepless adjustment like the MC4.
On a STEPPED grinder when adjusting finer, the grinder should probably be running. Definitely so if going finer than a couple of degrees.
On a STEPLESS grinder, when adjusting finer more than a couple of degrees [ 0r 720° on the MC4 et alia worm adjuster], the grinder should probably be running.
At no time should the grinder be run for more than 30s without an explicit duty cycle indication from the label.
When adjusting coarser, the burrs are unloading beans. If they jam, it's more than likely they would jam under normal operation.
It never ceases to amaze me that stating provable positions by some makes them dogmatic yet rote recitation of provably false positions by others is in karmic resonance with the universe.
