Just wondering if I could get some quick technical support. I've been passed down a La Pavoni PGB (branded as the Enzo Mini Macho where I am) grinder, that needed its burrs replaced. So I ordered the new part, and took it down to my local store where they dissasembled it and installed the bottom burr. I was then given the instructions on how to fit and adjust the top burr, and reassemble the whole think.
Back at home, I replaced the top burr, but ran into problems when adjusting/installing it. I was told that once fitted (loosely) back on, I should turn on the machine and check that the burrs where going, then turn it off and adjust the top burrs slightly tighter, untill the burrs where both going well.
However the problem comes in that i think I must have over adjusted it or something, and when I turned it on, the top bit got jammed suddenly, and currently isnt budging (at least by hand). I was just wondering if anyone could explain how I went wrong, and offer any ideas on how to fix things. The attached photo is just a town down view of the machine. You can see the top (jammed) burr ring part.
Note: Have also posted this over at coffee geek (http://www.coffeegeek.com/forums/espresso/grinders/422313#422313 ) as I'm looking to get this solved asap - ideally before my machine arrives on Friday.
Thanks in advance for any assistance
