by cannonfodder on Wed Jul 08, 2009 10:20 am
Grind adjustment, if you are making small adjustments like changing the grind one or two clicks either direction to fine tune a blend, I dont worry about running the grinder while adjusting. If I am making a half to full number adjustment, which is pretty large, I will pulse the motor a few times while adjusting.
The counter on the doser, not really sure. In a cafe where they run the doser full of coffee and have the star adjusted for a specific dose, one pull would be one shot. So you could use it as an index to count how many shots you have pulled in a day. Beyond that, useless.
Grind per dose, not really what the machine was designed to do, along with every other commercial grinder on the market. Some of the smaller home grinders were designed that way and the Versalab was specifically made for dose per grind work. Flat burr grinders suffer much less popcorning than conicals. You will still get a little, but no where near as much as a conical. My Max will occasional pop beans completely out of the hopper if I have the lid off while cleaning it out for the next blend. You can still dose per shot, but you have to consistently dose per shot. Your grind will vary from the beginning to the end. As the bean column gets chewed up, the back pressure drops, as it drops the grind gets coarser. If you keep enough coffee in the hopper to keep it level with the top of the hopper inlet, you are pretty safe. Once the bean level drops below that you start to get a big drift in the grind. I keep about 4 shots worth of beans in the hopper and have no issues.
Dosing, get yourself a scale, dose into the basket and weigh it instead of weighing the beans before you put them in the grinder. You can take the spring out of your portafilter so the basket will just drop in without messing up the distribution. After a while, you will get good at eyeballing it and not need the scale any longer.
