La Cimbali : Finger Guard or Bean Mass Regulator
Postby cafeIKE on Fri Apr 04, 2008 1:35 pm
Dave Stephens [cannonfodder] postulated the tube shown below is a finger guard.
It's effective for fingers up to about 4 inches.
Perhaps another reason the La Cimbali grinders do so well is the tube regulates the bean column above the burrs. If one fills the hopper from the front, a relatively fixed column of beans is always above the burrs. If one fills the hopper over the tube, after a couple of shots, the tube is empty and the bean column is established.
"Inquiring mind wants to know." :wink:
cafeIKE
Postby HB on Fri Apr 04, 2008 10:09 pm
It may be that the finger guard serves two roles by design as you suggest, but only if Cimbali expects that cafes consciously keep the hopper less than half full. From what I've seen, most cafes cannot resist the urge to pack coffee to the top. FWIW, the big Mazzer grinders do not have a column; just an "umbrella" over the throat.
Postby cafeIKE on Sat Apr 05, 2008 2:24 pm
HB wrote:It may be that the finger guard serves two roles by design as you suggest, but only if Cimbali expects that cafes consciously keep the hopper less than half full.
We're not cafes, are we :?:
I've never noted any consistency in cafe hopper levels, finding them range from chock-a-block to gasping on fumes.
In a cafe, the grinder model has even less relationship to espresso quality than CO2 does to global warming. :twisted:
cafeIKE
Postby HB on Sat Apr 05, 2008 2:38 pm
cafeIKE wrote:I've never noted any consistency in cafe hopper levels, finding them range from chock-a-block to gasping on fumes.
Indeed, you have answered your own question.
Postby cafeIKE on Sat Apr 05, 2008 3:02 pm
HB wrote:Indeed, you have answered your own question.
I fear not. Let me rephrase it : "Does the purported finger guard on La Cimbali grinders have an effect on grind consistency due to regulating the bean column above the burrs when used as is typical in a home environment, i.e. the hopper is usually less than half full?"
cafeIKE
Postby cannonfodder on Sat Apr 05, 2008 11:19 pm
Not that I have noticed. My observation, once the bean column rises above the hopper opening, the grind settles out. My shifting grind is most prevalent once the bean column drops below the hopper opening. I take no great care when dumping in beans, I jut lift the top and dump in a half pound of coffee and it has worked just fine for me.
cannonfodder
Postby zin1953 on Sun Apr 06, 2008 12:22 pm
In the FWIW Dept, the column seems to grind first -- that is, when pouring in the proverbial half-pound of beans, the column is filled (I tend to add it directly over the "finger guard/bean mass regulator"). :wink: When turning on the Cimbali Max Hybrid, the column tends to drop first, and only then are beans "added" through the side slots.
In other words, since the column "drops" first, it's hard for me to see how it's a "bean mass regulator."
Cheers,
Jason
zin1953
Postby cafeIKE on Sun Apr 06, 2008 2:01 pm
zin1953 wrote:In other words, since the column "drops" first, it's hard for me to see how it's a "bean mass regulator."
Once the tube has emptied after the first couple of shots, the bean column remains constant until the grinder is almost empty, unlike my Macap that has a constantly changing column of beans above the burrs. Hence, the 'regulator' effect.
Dave probably has it right in the grind remains pretty constant until the grinder is almost empty.
cafeIKE
Postby zin1953 on Sun Apr 06, 2008 3:07 pm
cafeIKE wrote:Dave probably has it right in the grind remains pretty constant until the grinder is almost empty.
Well, that's been my experience . . . the grind is constant until the hopper itself is almost empty.
zin1953
Postby Cafesp on Sun Apr 06, 2008 7:18 pm
cafeIKE wrote:Once the tube has emptied after the first couple of shots, the bean column remains constant until the grinder is almost empty, unlike my Macap that has a constantly changing column of beans above the burrs. Hence, the 'regulator' effect.
Couldn't agree more than that
Love's in the air, Taste it!
Cafesp
Return to Grinders
