caleb105 wrote:1 - Use a static screen. This screen is grounded to the body of the grinder, and helps to remove the static charge from the grinds before they ever reach the funnel
In my experience this does not work well.
caleb105 wrote:2 - Use a metal funnel that is grounded to the body of the grinder. That way, even when the statically charged grinds come in contact with the grinder, the charge is passed through the grounded funnel and there is no longer an electron attraction between the grinds and the funnel
Tried this too, metal grounded funnel does not do diddly.
caleb105 wrote:3 - Use a non-conductive funnel (i.e. plastic) that will result in a weaker electron attraction between the charged grinds and the funnel surface.
Have not tried this but it can't be any worse than metal funnel...
