danetrainer wrote:What is the noise level compared to other small espresso grinders, like a Nemox Lux?
Here is my first attempt at a video - Spielberg isn't going to lose any sleep but it does give a sound byte.
EricBNC wrote:What exactly makes it stepped anyway? It marks steps when these ridges:
meets this pin:
The pin is spring loaded - attached to this external release button to allow for fast removal of the top of the burr chamber.
Add a piece of tape over that release button and the steps are gone.
peter wrote:If you disable the detente pin, you'd have to hold the hopper/upper burr in place while grinding, else it will walk.
danetrainer wrote:Two Questions:
What is the Burr size? I have a Bodum Bistro grinder with the identical looking burrs...they measure around 28-30mm depending where exactly you measure (upper or lower burr).
danetrainer wrote:Although it says "Die Cast" that doesn't necessarily mean it is a metal housing the burr carrier mounts in, what do you find as far as metal vs plastic here?
No info at all on KrupsUSA site, I just emailed them as to why...
yakster wrote:Nice first look and an interesting grinder at a good price point.
Did you look at what difference in shot time you would get for a step above and a step below the dialed in point?
NaGR wrote:I guess you didn't have to shim it in the first place. I mostly grind in the 9-11 region and if I get down to 5 it is way too fine for espresso no matter what your beans are or how stale(god forbid) they might be.
NaGR wrote:I have the EU version under the Graef name, and I'd say a step in grinding finesse equals to about 4 sec difference in extraction time on average. don't know if that says sth about the burrs or plastic carrier indentation width.
We thank you for your email via KrupsUSA.com.
This model is not listed on our website which is controlled by the marketing team. We can suggest that they put this unit on our website. You can see the grinder and descriptions on retailers websites, such as http://www.amazon.com and http://www.macys.com. If you have a specific question that I can help you with, please reply.
