Kalita Nice Cut Mill - Page 6
- eastpresso
From the pictures the yellow r220 Kono is the flatburr (cut version)? Fuji is selling it as 'espresso capable' in Japan. There's also a flatburr version of the r440 which they deem 'espresso capable' as well (no upgrade path from the usual burrs). For some reason they wrote me that this 'espresso capability' is only for home machines and not for commercial machines (maybe due to a limited range of adjustability?). Any thoughts on that for the r220 flatburr?chang00 wrote:Here are several pictures of the Jericho version of the Kalita Nice Cut (KNC), along with the Fuji Royal R220. Additionally, I also have some comparison pictures of the Kono "bumblebee" version of the Fuji Royal R220 with "ninja teeth", courtesy of Jano
- Shenrei (original poster)
- yakster
Shenrei,
What are your impressions in the cup thus far? I believe in a separate thread comparing the 220 to the Versalab and Skerton, Henry had mentioned that the resultant brews were clean, little to no bitterness, but (at worst?) boring (and Skerton had offered, relatively, the most balanced cup). Your thoughts?
I've been using the Kalita Wave for all of my brews.
First cup I made was as Henry said: smooth, very clean, but lacking some sharpness. It was very mellow, quite boring, but had fantastic texture.
Second cup I dialed-down the grind a bit finer. This doesn't always work with pour-over IMO, but was worth a shot. Flavor improved a bit and some sharpness was present, but I enjoyed the first cup more even if it was more boring.
Third cup, I used the same grind setting as the first cup, and stretched out my bloom time longer than I'm normally accustomed to. Noticeable improvement here, and I believe it can get better via temperature adjustment, up-dosing, or using a very slow continuous pour. Maybe even using a steel catch-cup so I can get all of the fines.
Lots of things to try.
- Tim
Just mist the beans and there will be no static with the plastic catch.
There is also another model called R220P that is cutting teeth (not ghost teeth) with stainless steel body, just to add to the confusion.
Henry,
Have you had experience with the cutting teeth model?
Shenrei,
I notice you have quite the repertoire of grinders! I'm in the market to get a new brew grinder and have been going back and forth over multiple options (Lido 2, Vario with ditting burrs, Virtuoso, etc.). In your limited time with the 220, how would you compare it to others in your stable? Have you tried any immersion brew methods with this grinder? Perhaps it's more well-suited to that?
Shenrei,
So far I am enjoying the R220 over every other brew grinder I've tried, but this isn't based solely on cup quality. Forgiveness factor, ease of use, features, and repeatability are also considered. All of the grinders you listed (Lido 2, Vario with Ditting, Virtuoso) all make great cups. I think that the Virtuoso tends to get overlooked here and passed up because of its lower price but it's fabulous grinder capable of making delicious brew. Remember Nick Cho was using a Virtuoso in his Man vs Machine battle.
As for full-immersion brewing, I've only done FPs on the Forte, the Virtuoso, and the EK. The Forte was by far my favorite for FP brews which came out smooth and mellow, with subtle nuances of flavor. The Virtuoso was similar, but without the smoothness. The EK tended to be very clear and sharp, and my palette didn't like it so much. This isn't very scientific, but it's based off the multitude of brews i did every day, which included sifting and non sifting, and variations in dwell time.
- Tim
How would you compare the Virtuoso Vs. the R220?
And is there a 220V version of the R220?
Perhaps we should start a new thread related to the Fuji Royal 220 (or just re-title this thread)?
Shenrei,
In your opinion, does the result in the cup warrant the price premium of the R220 over the Kalita?
Shenrei,
