Kafatek Flat Burr Monolith Grinder - Page 7
I talked to him on the phone other day and he said the change is due to supply problems. He tested before with 75mm Tn burrs and 80mm steel burrs and decided to go with 80mm steel burrs due to high price of 75mm Tn burr which go for $440... With supply problems for 80mm burrs he switched to more expensive 75mm Tn burrs and kept the price the same.FotonDrv wrote:Was the reason for this a burr supply issue, or just better burrs? Denis might have tried the 75mm Tn burrs and though they provided a better taste in the cup, but that thought is just speculation.
- FotonDrv
WOW, good for Denis! Thanks for the feedback.
- TomC (original poster)
Denis just posted an impressive 22% EY on Heart Stereo Blend using this grinder with the 75mm titanium burrs.
- FotonDrv
Just placed an order....
- dumpshot
Was it the 22% EY that pushed you over the edge?
LMWDP #484
- ProletariatCoffee
- Supporter
wohoo, cant wait!
follow my coffee adventures on instagram @proletariatcoffee
- FotonDrv
No, it was just the fact that it appears to be a high quality , single dose, big flat that uses tried and true burrs.dumpshot wrote:Was it the 22% EY that pushed you over the edge?
I know myself and I might make a few modifications after using it for a while but it would be just cosmetic stuff, and maybe a way to hold a basket or PF under the spout for dosing directly into the PF. That would be something I would try and work out but I am sure Denis has put a lot of time into using and trying to improve his design so I suspect my tinkering with it is just a busy work exercise for me.
- jitters
As to the portafilter holder, when I ordered my Monolith Flat a couple of weeks ago, Denis told me he plans to include one on the Flat model.
- FotonDrv
That would be appreciated. Thanks for the info.
Here is what the fork will look like on the FLAT grinder. The portafilter lock in tabs will fit in the grooves making it stable enough to be hands free. Height adjustment can be seen in the rear of the fork.jitters wrote:As to the portafilter holder, when I ordered my Monolith Flat a couple of weeks ago, Denis told me he plans to include one on the Flat model.
Bob
