Is Zassenhaus 156 Kneemill suitable for espresso - Page 2
Postby espressoed on Wed May 14, 2008 3:20 am
cannonfodder wrote:To each his own. As a said, it did produce a shot but I personally did not care for it, but if my two choices were a whirly blade, preground or the hand mill, I would go with the hand mill in a second.
Um, Dave aren't those three choices? On second thought, given those options I guess it's really only one choice: the crank. :wink:
I'm kinda curious about that Zass knee mill labeled "espresso" and given a different SKU number than their other knee mills. Is it actually different from the others outside of having an "espresso" label on it? If so, too bad it's not available in N.A. I believe Mark Prince at one time also took note of this mill but didn't have any info on it. Can anyone else shed any light?
All the coffee in Ethiopia won't make me a morning person.
espressoed
Postby SteveN on Wed May 14, 2008 12:43 pm
I have a Zass box mill I bought from Sweet Marias about 7 years ago. I sold my Rocky and I am using it while I wait for the Cimbali Hybrid to be back in stock.
It makes an ok cup. I find it is better to leave the adjustment and change to dose to hit numbers. I do like that if I put 17 grams in, I get 17 grams out. I get good consistent pulls but the flavor is flat. Even my unsophisticated taste buds can tell that. The burrs are touching when I grind but SM said that is fine so....
-Steve
SteveN
Postby woodchuck on Wed May 14, 2008 2:07 pm
I have a Zass 156. I use it as my second espresso grinder (M4 is the primary grinder) and for my press pot. I pretty much screw it down until the burrs touch for espresso. For press, it is excellent - takes no time at all. For 16gr ground for espresso it takes a good couple of minutes of cranking but the results are pretty consistent. Would rather have a second M4 but the better half has ruled that out. I wouldn't use this as a primary grinder but for a second grinder it works fine.
Cheers
Ian
woodchuck
Postby peacecup on Wed May 14, 2008 3:23 pm
I have little experience with Zasses, and the ones I've used have not ground as fine as some other hand mills I have. Most of the ones I use regularly have ball bearings to center the inner burr, but I'm not sure all of them do.
I'd like to propose a test to all those convinced that they can taste differences between hand grinders and the more expensive electric version - dial both in with your favorite beans, then grind enough for a shot with each. Figure out a way to do a blind test (e.g. mark the baskets, etc), then do so. I'd like to know how many of you honestly can say that your electric grinder tastes better. If anyone decides to accept the challenge, remember you'll need to do it at least five times, probably ten or more, to provide anything like a "significant" result.
PC
LMWDP #049
peacecup
Postby Psyd on Wed May 14, 2008 4:21 pm
peacecup wrote: I'd like to know how many of you honestly can say that your electric grinder tastes better.
PC, I tried to give the impression that, if anything, the shots from my PeDe were better than those from my Majors. No scientific data, but that's the impression I was left with.
Speaking of scientific data, I'd rather have a mill that I can use now than experiment with the present 156 to see how it progresses. It will be my travel mill to go with my travel kit, and I need something that performs. The PeDe is nice, but it's old and fragile, and I need something a bit more robust.
If you'd like to continue the experimentation, however, I'd happily get you the grinder for whipping and what I have into it... ; >
I'm still trying to find someone that can tell me what the differences between the espressomuehle and the kaffemuehle are, and how to tell one from another. Ya know, for future purchases.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Postby peacecup on Thu May 15, 2008 2:11 am
I actually left an Zass behind when I moved, due to space limitations. It did not seem to work as well as some of my others, but I did not give it much of a chance.
I have one Kym grinder that for some reason I sometimes "felt" made a better cup. Never tried to compare, or explored why. Maybe I'll have a go when they arrive.
Two months without an espresso machine is a LONG time....
PC
LMWDP #049
peacecup
Previous
Return to Grinders
