So I thought I would give the grinder gurus here something new (maybe) to ponder.
In summary, I kind of accidentally found out that you can put burrs for a Cimbali Jr grinder in a Mazzer Super Jolly, so I am sure you can do vice versa, although I did not actually try that.
Long version.
I happen to have both a Cimbali Jr grinder, and a Mazzer Super Jolly at the same time. I bought the Jr from Craigslist, but have had some problems with it, see here
Used Cimbali Cadet hard to adjustI am still working on the Jr, and I am making progress, but it has been slow. Will get it working one of these days.
In the meantime, I lucked into an Ebay auction that sent a Super Jolly (SJ) and two Majors my way. Unfortunately, all of them had rusted burrs, I think the seller was not careful with when cleaning them, and got stuff on the burrs that caused the rust.
The SJ was fine, except for the burrs, so I decided to see if I could use the Jr burrs. I had bought new burrs for the Jr, and they are collecting dust until the Jr gets fixed.
I compared the burrs, but did not measure them, and for some reason decided they were the same.
You can see pictures of the burrs here
http://drop.io/randy_burrs#The two rusty ones in the same picture are the old ones I pulled out of the SJ.
The other two pics are the new ones I bought for the Jr.
They clearly have different patterns.
I installed the Jr burrs in the SJ, and put things back together. It still zeroed out at the same place it had before, and it ground fine. So, I am pretty sure the burrs are exactly the same size. I ran a ¼ lb or so of beans through it, just to try it. The next morning I pulled a shot, and it worked fine, I was able to get a 25 sec, 1.5 oz shot after a few tries.
I was wondering if anybody else had stumbled on to being able to interchange burrs like this?
And this leads to another question, what would happen if you compared Mazzer to Cimbali burrs in either a Jr or in a SJ? Would Mazzer burrs work better in a SJ, or would one set of burrs always beat the other set?
And, are there other 64mm burrs that you could use in a SJ or Jr, from another grinder?
The other think I was going to compare tonight, when I get home, is the old Cimbali burrs to what I have. I remember thinking that the old Jr burrs don't look like the new ones. It is actually not a Jr, it is labeled an Alinox, but it is the direct drive version, and it appears to be the same as the Jr. The burrs are probably original, and at least 10 years old.
Randy
