Initial grind setting for Profitec T64 grinder
Hi All,
We just purchased a Profitec Pro 700 and the T64 Grinder. I'm curious as to what numerical setting most people find that they are using to get the optimum shot. I think that we're at about 8 which is much higher than I thought.
Anybody else?
George
Anybody else?
George
Grinders aren't typically calibrated the same and are all different, someone else may need a 13 to get similar results as your 8. Makes new grinder fun , people regularly go through several pounds of beans with new grinder to get it dialed in. Also, new grinders are finicky until the burrs are broken in, won't likely start seeing optimal results until after 20-30 pounds.
- HB
- Admin
Comparing your grind setting against other owners' zero point will be more meaningful since the numbers are not always the same unit to unit. For example, Mazzer adds a "Start Here" sticker post-assembly for that reason. To find the zero point, empty the hopper and chamber, then run the motor while slowly turning the adjustment finer. Eventually the burrs will contact and "chirp". That's the zero point. Assuming your T64 is like other 64mm grinders I've used, the espresso zone will be 1/4 to 1/2 turn coarser from that point. If you're concerned about the burrs touching, refer to Grinder burrs touching is the "kiss of death"? for an explanation of why there's no need to worry.
While I'm handing out free links, also see Fine tuning grinder setting with minimum waste; the "feel" technique is demonstrated in Newbie Introduction to Espresso - Grinders.
Suppose it doesn't matter as long as you have room to adjust either way.
______________
Alex
Home-Barista.com makes me want to buy expensive stuff.
Alex
Wow. Ok! We're definitely learning - so I appreciate the advice. I have to say, I'm certainly caffeinated these days!
Tasting without drinking will save you some jitters!GeorgeM wrote:I have to say, I'm certainly caffeinated these days!
Agreed - I didn't think that I'd get to that - feel like I'm in Napa valley - but essential when you're trying to get things going the first time.
George
George, how is the grinder working out? I am planning on picking up a Profitec 300 or 700 plus the grinder in the next month or so.GeorgeM wrote:Agreed - I didn't think that I'd get to that - feel like I'm in Napa valley - but essential when you're trying to get things going the first time.
George
-Doc Todd
- thecatch83
I have read that some people are bashing the pro T64, but what other sub $1k grinder offers 450 watts, 64 mm burrs? It utilizes a worm drive adjustment similar to Macap (which I love), and if you watch the videos, there is almost zero clumping and the grinds dose directly into the PF with minimal spillover. The Gicar PID is a nice touch as well, and replacement parts are abundant.
- caldwa
If I wasn't buying the new Baratza Sette 270W - the pro T64 would likely be my grinder of choice. Love the simple, well-constructed design and big features in a small footprint.
