JohnB. wrote:I've installed new burrs in two Majors I refurbished & didn't have any issues. Have you opened up the burr chamber & inspected the burrs for defects or loose screws?
Yes, I inspected the burrs last night and they looked fine.
cannonfodder wrote:Donut extractions are usually a dose/distribution/grind setting issue. What is dosing weight? Often, lowering the dose, tightening up the grind and go very light on the tamp will fix the issue. The burrs will need a little seasoning. The major is some serious sized burrs in it. You may want to give it 20 pounds before you declare the burrs broken in.
I just tried using a double basket (I have previously been using triples) and the extraction was much, much better. I dosed 16 grams, tightened up the grind quite a bit and the pull was a nice, gloopy ristretto. It was bizarre to watch after spending the last few days trying everything I know to get an even extraction. I've used triple baskets with this coffee before with very good results. How would you recommend adjusting my method if I want to try the triple again?
Thanks for your help, guys. That shot really eased my mind.
