Improved grind setting rings for Mazzer & Macap grinders - Page 2
- TomC
Thank you for doing all this work and sharing it here. Very cool of you.
It may make no difference to anyone, but a thought crossed my mind on the language used, have you considered, or will you consider having one that has "coarse" --"fine", instead of "grossa"? Just a thought.
Still very cool either way!
Really nice. I look forward to printing and installing! Thanks.
Added the English versions to the first post!TomC wrote:Thank you for doing all this work and sharing it here. Very cool of you.
Be sure to share a picture or two once installed
Happy to share! Let me know if the fit is good, if not, I can make some small size adjustments..ripvanmd wrote:Really nice. I look forward to printing and installing! Thanks.
- TomC
Whale wrote:Thanks
Monday or Tuesday I will try to go get some metalized adhesive printer paper and see what we gets...
I look forward to hearing about your findings. I like that idea of material.
That grind collar is looking sexy!
Kudos to OP, looks like an easy mod... print and stick... just damn awesome...
It could be as complex or as simple as you want. It's the choice of the barista.
Hi Doug, thanks for the praise! A little birdy actually gave me the idea for the ringsDougST1 wrote:Dude, this is awesome! Did you come up with this all by yourself?
For the macap m4c please make inner ring 1mm bigger and outer ring 2mm smaller.
<image>
Updated the Macap M4C design, give it a try!
Tamp away!
Very cool- I'm going to get one on my Mini for sure. Thank you for posting!lfanchi wrote:Hi all,
I grew tired of not having a clear scale on the grind setting ring of my Mazzer Mini, so I made it myself in Photoshop
Thought maybe someone would be interested as well, so here's to sharing!
