by sosusume on Mon Jan 31, 2011 1:54 pm
I did the unthinkable...I bought pre-ground.
I liken pulling a descent shot of espresso to golf...you have your good days and bad days. Eventually though, you just toss your putter or wood and give up.
Ten years ago, I bought my first NS Mac and grinder, the old version of the NS mdx, and was up and running. I was given the usual, single and double portafilters, and blind. I had no idea what the pore-less gizmo was, i.e. blind filter, hence tossing it away. The grinder was set for me, I was given step by step instruction on dosing and tamping, and was left on my own. What fun! I fiddled with it, got what I thought were espresso shots...ugh!, and very wet and massive-bubbled milk...hey, but it was hot! Good. Anyways, after using the machine for years and drinking very abysmal coffee (notice I didn't say espresso), never back-flushing once, it came to a slow and painful death. Well, no big deal, I'll just get another machine. So, moved on to a newer and shinier NS model, and again never told what the solid insert was for - no I did not shop around, I did not compare, I did not look on-line, after all, a machine is a machine, right? Within a month, we moved and since the machine was a plumbed model and not wishing to drill into my new granite top (actually, husband wouldn't justify it), my month old machine went into hiding.
I went back to my local coffee house (thankfully) and found another hobby, then bought a superautomatic to feed my addiction, until one day, low and behold, I discovered I could use my machine without having to plumb it in...a pump! So, I called my good man back and had him install a pump (and he suggested a descale..what in heavens name was that) and since I was in a good mood, why not get a new grinder. My second NS grinder, Grinta. I'm sure by now you've figured out the common denominator of my angst!
Before using my still new machine, I went on-line, (namely Home-Barista dot com) learnt what I can and Holy Cow, that blind thing actually served a purpose...who knew. There were brushes to use for the group head, back-flushing detergents, and tampers that were not made of plastic? There were methods for producing microfoam- purge first - and, apparently, plunging the steam wand over and again was not correct. You need to time the shots, flush before pulling...etc. Huh.
Now armed with all this knowledge, I ordered a new ss tamper, grouphead brush, grinder brush, timer, shot glasses and my new favourite, bottomless filter. Great news...I was getting great LOOKING shots, but sour and bitter, milk still bubbly. Try and try, but to no avail. I tossed my putter and went back to my coffeehouse. Then, I came back...I plugged two of the four holes with toothpicks, went out and bought pre-ground Illy espresso, and I was finally getting the best tasting espresso and the smoothest microfoam known... to me anyway.
So, bottom line, what I've read on here is gospel...your grinder is the most important tool for good espresso.
