www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
How to remove doser section from Rossi RR45
Postby ajahearn on Thu Sep 29, 2011 6:24 pm
I purchased a used Rossi RR45 grinder. The pictures and diagrams I find on-line all look identical to mine, with a few minor differences. My switch is not a lighted rocker style but rather a metal toggle style. The bean hopper does not have the internal attachment I see in some pictures.
But the one critical difference appears to be in how the doser is attached to the main housing. In all the diagrams and pictures I find, the doser is held on by a hex head screw that is screwed in below the doser star. In my case the screw is a flat head screw and won't budge. Anyone have any suggestion on how I can get it off? I could try drilling it out but I really would rather not. I obviously can't use any kind of liquid screw loosener either.
Thanks in advance.
ajahearn
Postby allon on Thu Sep 29, 2011 7:28 pm
Mine has the flathead too.
It is essential that you have the properly fitting screwdriver so you don't munge up the slot. Use a tooth pick or dental pick to clean out the slot so you get a solid hold with the screwdriver. Take it easy.
LMWDP #331
allon
Postby ajahearn on Fri Sep 30, 2011 2:13 am
Thanks. I will certainly give it another try.
ajahearn
Postby ajahearn on Sun Oct 02, 2011 3:10 pm
Unfortunately I tried the largest slotted screw driver sold by Craftsmen (3/8") and all I got was it started to strip. It's going to have to stay. Thanks anyways though.
ajahearn
Return to Grinders
