by jonny on Fri Dec 23, 2011 5:22 pm
I have never used a grinder with a static screen but from what I have seen and understand is that the grinds get compacted behind the screen and pushed through like a meat grinder, if you can envision that. Static doesn't cause clumping. It just causes grinds to stick to everything else (doser walls, etc.), not itself. You notice pretty quick when you have a static issue (grinds flying every which way as if pulled by magnets), but I haven't had any trouble with this on my mazzer. If you take the screen off, you should be relatively clump free.
