How do I get the plate with the three bolt holes off?
paul_pratt wrote:Jamming things in may cause damage to the shaft. An easier way is to use long bolts and tighten them in sequence. The bolts push against the main body and force the carrier off. The risk of damage is low because the amount of force required is very small.
See pics.
mikekarr wrote:So, this doesn't really seem to just be a thin steel plate, though I did manage to break a bolt off in it trying to push it up. I'm sure I can get the bolt out, but I still can't figure out how to get to the bearing.
eastpresso wrote: If you don't feel confident or don't have the right tools to remove the bearings (like me), only remove the stator and have someone else change the bearings for you.
