Help with Baratza Vario settings and dose size - Page 2
If you had a naked portafilter it would help you a lot as your problem may be channeling with early blonding. Once you ensure your puck doesn't channel, then you can tune your shot by taste/time/weight/volume/etc.
"Wait. People drink coffee just for the caffeine??"
LMWDP #628
LMWDP #628
this is spot on. also, seconded regarding the naked portafilter, or if you don't want to spring for a nekkid pf at this moment, just do weiss distribution technique on every shot. pretty foolproof.Matt_F wrote:1. Weigh 16g beans
2. Add to empty grinder, grind
3. Adjust grind until I get approx 2oz in approx 25 - 30 sec extraction
4. If I get early blonding grind finer
5. If I still get early blonding increase dose
6. Fine tune by tasting
Is this procedure ok?
also, play around with your dose to find what taste you like.
I think there are a few problems here.
One, a single espresso (assuming it's ~1oz), will get lost in 7oz of milk easily. I think that was already covered.
Now, even though Varios supposedly come out calibrated from the factory, it wasn't the case with mine. I would pull a shot with 1-B grind and naked portafilter would spray coffee around (meaning it wasn't nearly fine enough). I took the tool and calibrated it. If you don't choke your machine with a fine setting, you need readjustment.
