Help please with cutting the axle of the Pharos
I am stuck.
I thought I was stuck because I needed a new mandrel for the Dremel, but....it's worse than that.
The reinforced cutting wheel for the Dremel is only 1 1/2" in diameter and it's impossible to get an angle that will allow me to hold the axle in the vice and cut a straight line across the axle.
So....what do I do next?
It's raining; it's a perfect day to get back to modding the Pharos, but....I need the right tool for the job and I don't know what it is.....
- bostonbuzz
A hack saw to cut, and some coarse sand paper to clean it up. Get a good blade, stainless steel is hard. A vice will help as well.
LMWDP #353
You can also search for local machine shop and take it to them... They'll probably do it free of charge or for very low fee...
- Randy G.
carbide hacksaw blade?
Cool.
Thanks....
Back to Home Depot...
Susan
Thanks....
Susan
- rpavlis
Stainless steel alloys are notorious for work hardening. That means you must have sharp tools that cut rather than deform the surface. Dull bits are a disaster! Stainless steel alloys are hard anyway.
Got it cut....hacksaw did the job.
Thanks for your help.
- spressomon
Sorry Susan I was gone this afternoon...but as you now know a standard fine tooth hacksaw blade sails right through the Pharos shaft. There are different stainless alloys and relative hardness...fortunately not too hard on the Pharos.
No Espresso = Depresso
