tekomino wrote:If you can get some of the fruit polishing wax (perhaps ask for some in your grocery store) you can take bottom funnel off, clean inside with acetone then polish off with the fruit wax. That should reduce the clumping.
Even if you get little clumps/stack, just flick them and they will fall apart. They don't make any trouble...![]()
Technique wise, I collapse volcano by just flicking it from outside so it falls in, then just gentle side-to-side shake of portafilter to level that, tamp and go.
Enjoy.
Lowlander wrote:Thanks, but that is not what I mean. I mean the clumps that fall down in the portafilter.
And I do use it.![]()
I
hperry wrote:You should not get any clumps in the portafilter. Check with Versalab. I have never had a clump in the history of the machine.
