Aergrind: compact coffee grinder by Knock (Kickstarter) - Page 2
Salvatore did a kickstarter a while back for his compact spring lever. I think it's viewed by some as a way to get a quick influx of cash and some publicity. His machines were delivered within a couple months of deadline, not bad for kickstarter.sweaner wrote:I have to wonder why an established company really has to use Kickstarter. Just invest in your business and make the product, a la Orphan Espresso.
- Supporter ★
"It's not anecdotal evidence, it's artisanal data." -Matt Yglesias
- baldheadracing
Backed. It doesn't have a plug, which is a good thing for Kickstarter. Also on the plus side, the burr is a known quantity, and my Al-bodied Hausgrind works well.
On the other side, there are those issues alluded to in prior posts. The August 2017 delivery is - my guess - optimistic. I am expecting zero updates other than the odd Instagram pic. I will be happy if the grinder gets to me a year from now (I'm still waiting on most of my Kruve ...).
- Bob_McBob
The 25g capacity makes it a nonstarter for my typical usage, but I guess many people only ever brew single cups. I understand the appeal of fitting in an Aeropress (a criticism of the Feldgrind when it was released), but the Feldgrind is already incredibly easy to travel with, and ~13cm vs. 19cm height doesn't make much difference to me. Most of the weight savings seem to stem from the unibody construction vs. the Feldgrind's chunky separate grind unit. I'm concerned about the thin body wall and how well large beans will feed through the narrow openings around the bearing mount.
Chris
- Supporter ★
Yeah, I got a bit of a Helor vibe from that aspect of it. Valid concerns to be checked up on. I backed.Bob_McBob wrote:Most of the weight savings seem to stem from the unibody construction vs. the Feldgrind's chunky separate grind unit. I'm concerned about the thin body wall and how well large beans will feed through the narrow openings around the bearing mount.
Maybe I don't see them, could someone tell me the innovations of this new grinder? there are many hand grinders out there with different prices tags and sizes, it's a really competitive market niche
D.
D.
For me the big difference is 300 g. That is almost the difference in weight between the feldgrind and Lido 3!Bob_McBob wrote:The 25g capacity makes it a nonstarter for my typical usage, but I guess many people only ever brew single cups. I understand the appeal of fitting in an Aeropress (a criticism of the Feldgrind when it was released), but the Feldgrind is already incredibly easy to travel with, and ~13cm vs. 19cm height doesn't make much difference to me. Most of the weight savings seem to stem from the unibody construction vs. the Feldgrind's chunky separate grind unit. I'm concerned about the thin body wall and how well large beans will feed through the narrow openings around the bearing mount.
The walls don't look thinner than on a porlex. The porlex is of course not known for build quality, but I have also never heard of issues with the walls.
I'm also concerned about the bean feed...
I really don't need another grinder, but having been looking for the ultimate travel set, I couldn't help myself from backing at that price...
- jesse
Awesome. The ultimate travel/backpacking grinder if the grind quality ends up being on par w/ the Feld and Haus. If so I am definitely picking one up.
Naturally, this is pure speculation, since nobody has seen it:ebola5114 wrote:Maybe I don't see them, could someone tell me the innovations of this new grinder? there are many hand grinders out there with different prices tags and sizes, it's a really competitive market niche
D.
What I like in this grinder is
- Coming from Knock, I can expect a good grind quality
- Weight. 300 g is nothing. That's half of felgrind or Helor!!
- Size is less of a concern, but smaller is nicer.
- The grind dial. Easy to use like the feldgrind, but seemingly with more precision thanks to a larger dial.
- A lid. The dial being a lid is great for putting it in a bag without getting stray coffee particles all over the place (Hi, Helor and Kinu).
- The price is relatively low, even after the kickstarter.
Some main alternatives would be feldgrind, Lido, Helor, Kinu. All are great and sturdier built. Perhaps grind quality could be discussed, but let's not get into that without information.
However, based on what I've seen, I can't see any clear disadvantage of the aergrind, beyond build. (possible feed issues mentioned earlier?)
It seems to be optimal for travelling, and for those not travelling, it comes at a lower cost.
- redbone
I'd like to see Knock go the other way and make a manual table top grinder with something like a 68mm conical.
Non portable sturdy, easy to set and lock grind settings and remove grinds.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
