Has anyone made a doserless from the Nuova Simonelli
- espressme
Are you filling the doser up? I would not recommend doing that. Instead do what's called single dosing. Put your beans in a separate container and weigh out your desired dose then dump it into the hopper. As it's grinder put your portafilter under the doser and repeatedly pull the lever (thwack-twack sound) to break up clumps and get all of the coffee. Dan has done a good illustration of this in one of his Newbie Introduction to Espresso video's.
- espressme (original poster)
[quote="LukeFlynn"]Are you filling the doser up? I would not recommend doing that. Instead do what's called single dosing. Put your beans in a separate container and weigh out your desired dose then dump it into the hopper. As it's grinder put your portafilter under the doser and repeatedly pull the lever (thwack-twack sound) to break up clumps and get all of the coffee. Dan has done a good illustration of this in one of his Newbie Introduction to Espresso video's.
Thank you!
Good point, I do that already. But, I want it for another grind than my Cremina uses and the hassle of multi thwacks is is frustrating. I've converted others but thought this one may have a weirdity that would cause a disaster if I tried.
Thanks though.
~Richard
Thank you!
Thanks though.
~Richard
richard penney LMWDP #090,
Only one way to know! Take the doser off and see what the structure is like.. you could probably do one of those coke bottle mods.
Thanks Luke,
Did that with a few different ones a while back. Getting really lazy in my old and decrepit state.
Thanks
~Richard
Thanks
~Richard
