The harbinger of the new Pharos?
- baldheadracing
http://www.oehandgrinders.com/OE-PHAROS ... _p_77.html
OE PHAROS Split Shaft Adjustment Collar - 2015 Model
Part Number OE-PH1-C-2
Your Price: $8.50
Availability: Out of Stock
DESCRIPTION
Threaded Split Shaft Adjustment collar for the OE Pharos Manual Coffee Grinder. Fits ONLY the 2015 Pharos Models
http://www.oehandgrinders.com/OE-PHAROS ... _p_37.html
OE PHAROS Split Shaft Adjustment Collar - USA Made Model
Your Price: $8.50
DESCRIPTION
Threaded Split Shaft Adjustment collar for the OE Pharos Manual Coffee Grinder. 1/2" x 13, Black Oxide finish. This is a coarse thread collar. Fits ONLY the original, hand made in USA Models.
Your Price: $8.50
DESCRIPTION
Your Price: $8.50
DESCRIPTION
- kaldi61
like you, i'm checking back frequently for any sign. But because it says for handmade in USA models only, I think this part is not for the next gen Pharos, which i thought was being finalized before toolup in Taiwan.
-Nelson
LMWDP #506 "It's not just for breakfast anymore."
- baldheadracing (original poster)
Sorry, I put the description for both the old and new part in the first post. I'll edit it better.
Actually, I was only checking for some parts to get back in stock, as I finally found a used Pharos and I need some bits.
- CoruscatingCoffee
I would like a more functional adjustment collar for my OE Pharos #804. The OE information says that this collar fits the made in USA models and on a different link it says it fits only those Pharos made in 2015. I need a collar for my #804. Is this it?
"Make me one with everything" said the Zen Master to the hot dog vendor.
- CoruscatingCoffee
By sifting through the OE website I answered my own question. I realized they were 2 different adjustable collars. Please disregard my original post.
- hankua
Reading the tea leaves; the updated Pharos will probably have a fine thread on the axle. That would be nice
- orphanespresso
- Sponsor
Yes, fine metric thread it will be. Getting closer all the time. About a month to go. All my assembly tools are in Taiwan. We have finalized all the parts and the burrs have arrived so as harbingers go, this is going to happen sooner than later.
Doug Garrott
www.orphanespresso.com
Looks like getting the grounds out of Pharos II will be similar to Pharos I. Are you going to be shipping them with a new reflex hammer?
Despite all the clever devices on this Forum for removing grinds from a Pharos, I find that shaking them into a small flask held firmly against the base around the opening - as Doug demonstrated years ago in one of his first videos on the Pharos - works fine. The only "mod" I use in this regard* is RDT (a quick spray of water on the beans before grinding). Grind retention is negligible.
Matt
*I do have some other mods on my Pharos, but they aren't related to grind removal.
Matt
