Dave measured the temperature of the grounds during the
Titan Grinder Project:
The folks at Counter Culture Coffee also measured the exit temperature of the grounds using an infrared thermometer during the evaluation of commercial grinders (their interest was how much coffee was heated during continuous use). IIRC, it peaked in the low 100°F's.
Though I've never measured, given that a manual grinder turns much, much more slowly than an electric grinder, it's got a lot longer to dissipate heat; I would expect the grounds to be heated less, especially because manual grinders don't see continuous use, so there's little retained heat in the chamber shot-to-shot.
Anonymous wrote:Im not trying to pick a fight with you,so dont go crying on HB about posts you dont like.
I'm lazy, resorting to a thought experiment supported by a few tidbits of experience. If you or your youtube commentator want to raise the level of discussion, post measurements and an explanation of how you measured. Otherwise, you may as well agree to disagree and move on.
