by Red West on Sat Aug 22, 2009 10:19 pm
I've been using a Kyocera hand grinder with a Europiccola for a couple of weeks.
I really like the Kyocera, fun to use, easy to dose. My only concern is the adjustment screw.
I'm paranoid that the adjustment is floating around (just paranoia, probably not reality), and I have a really hard time feeling the notches to dial back to the same spot. I saw someone had drawn guidelines marks on the adjustment knob, and I'll eventually do that to help the process.
My main query to the group would be: how does the adjustment of the Kyocera compare to that of some of the older hand grinders (I've never seen one in person)? Is there a particular model vintage hand grinder that is easy to dial in and lock to a particular grind?
