The second grinder is a bit more of a mystery. Like the first one, it's been painted and had decals applied, only not quite so nicely.
This one was so dirty and the burrs so clogged that when I took it out of the box and stuck some stale beans in to test it, they wouldn't drop through the burrs to the drawer. When I pulled the burrs out, the channels in the bottom burr were completely clogged with a concentrated tar of old coffee oils that nothing could get through. They took quite a bit of soaking and scrubbing, but, in the end, were in excellent shape with very little wear (I guess all that goo was a fine protective coating).
It's a finger-jointed drawer, but the rest of the box seems just nailed together.
Inside is clean and springs are intact.
I've seen this 'hourglass' type bottom adjuster before, but I don't necessarily associate it with any particular manufacturer.
Maybe the crank gives some clues, but I don't recognize anything.
It grinds well, though, fine enough to choke the Caravel (and the Synchrony, too). Not sure if it's a keeper or not. I'll have to give it a little bit more of a try.
