Laral wrote:It shows a simple hack that turns this so-so $20+ grinder into an amazing espresso grinder ... It works unbelievably well. The grind is extremely fine and fluffy. You could probably use it for espresso until you find a "real" grinder.
The burr set on the Cuisinart bears a strong resemblance to the flat burrs found on other cheapola entry level burr grinders, a burr set that Alan Frew describes as "
totally unsuitable for quality espresso production". Shifting the range of grind settings may allow you to grind
finer, but there's no reason to believe it will allow you to grind
better.
Have you actually tried this on espresso? Perhaps some experimentation is in order, before pronouncing this to be an "amazing" espresso grinder.
