Grinds collection tray for Baratza Vario
Hello,
I own a Varatza Vario. This grinder works very well, but grinds land on the counter and make a mess in front of the machine by the end of the day.
I was wondering if anyone has some sort of idea for a tray for collecting the grinds, similar to other grinding machines (like Mazzer).
I was thinking maybe using the tray from Fiorenzato F64 or Macap MC4 as they seem to have the similar convex front as the Barazta Vario
See images below
See images below
I don't think there is one specifically made for the Vario, but I would imagine a tamping mat like this one could work well. You can even trim the front edge to fit close if you like.
- baldheadracing
Rattleware has a grinding tray that I use: https://greenbeanery.ca/products/rattle ... cm-p-15003 (The tamping mat is not attached to the tray.)
That's not bad, but at 9.75" x 13" it's a bit too big.
I was hoping for something around 7"x8"
Yeah, that might work. Would this work under the front feet of the grinder? Or would it cause the grinder to tip backwards?Headala wrote:I don't think there is one specifically made for the Vario, but I would imagine a tamping mat like this one could work well. You can even trim the front edge to fit close if you like.
- dominico
Hello there, please don't cross-post to these forums (your equivalent post on CoffeeGeek). See Why is cross-posting strongly discouraged? for the rationale behind this policy. Moderators reserve the right to delete cross-posts.
Thanks.
Thanks.
https://bit.ly/3N1bhPR
Sorry about that. I know for the future.
i place the grinder in a tray, I have https://www.amazon.com/gp/product/B00IRUU046 and it works nicely, i can let grinds spew out of my grinders and not have to worry about cleanup. Once a week or two, ill use a portable vacuum and clean inside the tray.
edit: the tray allows me to also move it around for general table top cleaning as well (useful for the lady when shes cleaning the kitchen and i dont want her to touch the equipment) you could find a tray that fits your size.
That's a good idea, but I think I'd prefer something with a smaller footprint and made out of stainless steel.amagad wrote:i place the grinder in a tray, I have https://www.amazon.com/gp/product/B00IRUU046 and it works nicely, i can let grinds spew out of my grinders and not have to worry about cleanup. Once a week or two, ill use a portable vacuum and clean inside the tray.
Quick googling I found this 10 x 6 1/2 x 3/4 shallow stainless steel tray: https://canadawide.ca/Catalogue/Chemica ... 700.8/1347
yup there you go! I had to choose a larger one because my sette's static sprays grinds all over.
