I wanted to quote the relevant sections here and pose a few questions about them ...
Just for the avoidance of doubt, I want to point out that my comments in the first paragraph quoted above are not relevant to the topic of this thread. The timer on the SC that my friend bought was fine for the SC, but the
robur grinds faster, so he felt that it wasn't up to the task for the robur. That paragraph does not shed any light on using a grinder in the home environment beyond that. Well, and possibly beyond stating that adding a timer to a grinder has nothing to do with grind quality, but I would have thought that much was obvious.
An interesting note about consistency at home--definitely an eye-opener. I believe you're probably right about consistency issues from a timer, even a very accurate one. It's going to have significant issues needing adjustment after changing the grind or coffee, and maybe even as the day progresses (depending on how the atmosphere where you are grinding changes).
You've got it. Grind size and grind time are interlinked, so anything that throws the grind out of whack can also require a time adjustment. In a cafe, this isn't much of a problem because small changes happen constantly throughout the course of the day. In such an environment, timers can help to reduce wastage and keep up consistency.
If you find that you don't have to adjust your grind or dose much throughout the course of the day at home, you probably won't have to adjust the timer much and, in that case, you might be able to rely on it to get repeatable shots. If not, you will not be able to rely on it for repeatable shots. The point is that having a timer isn't a panacea for understanding how to use or adjust a grinder. If anything, having an extra thing to twiddle makes the process more complicated and not less. I'm sure that anyone who uses a timer will develop a feel for how to adjust it.
Still, you seem to think that a timer is still worthwhile (you like the Mini-E for home)--as you say, it's a huge convenience in terms of cleanliness and user-friendliness. I suppose you also like the big Mazzer Electronics for the same reason?
I haven't tried the E versions of the big mazzers yet and, so, can't comment. I came close to using a robur-E once, but the unstoppable torrent of drool coming out of my mouth shorted the power out.
I'm not sure where you get the idea that I think that the timer on the mini e is worthwhile from; I wrote that I like the grinder and that:
[t]he timers are, IMHO, almost useless ...
That is perhaps put a bit strongly; timers may well be useful at home if you don't have to make many grind changes and have other uses, as I will detail in response to the next section of your post.
The real reason why I like the mini E is because it provides decent grind quality and adjustability with a minimum of mess (because of the design of the funnel).
In all honesty, what annoys me most in my routine described above is that I have to count or risk grinding a significant amount too much coffee. To put myself up for a little bit of laughter, I will admit that sometimes I absentmindedly begin to count my thwacks instead of the "seconds" in my head, killing even the crummy timer that is my own brain. I would say that I waste between 1 and 3 grams of coffee per shot that I make, depending on how carefully I am paying attention. I guess that waste annoys me on principle (I painstakingly home-roasted that coffee and now I am throwing it away!?), but it's also the annoyance of counting out the grinder while trying to break the clumps with the doser thwack and dose evenly into the basket below. Do you think I am right to assume (as I have been so far) that a timer is at the least a good way to minimize waste from overgrinding while dosing? That is certainly what grinders that come with timers advertise, right?
Timers can certainly be useful in helping to stop you from grinding too much, in a few ways:
(1) I get the impression that folk expect timers to dole out the exact right amount of coffee every time, which certainly helps to keep waste down. As I mentioned above, in practice this might not work out at home.
(2) Timers can simply be used to get you in the ballpark. This is how I use the mini-E timer and why, as I alluded to, its timer isn't totally useless. One sets the timer to grind 90% of what is required, then tops up the rest manually. You will be able to use any grinder with a timer in this way as long as it has a pulse function. The mini-e is particularly good for this because it has a pretty decent portafilter rest, so you can have it do the bulk of the grinding whilst you are filling up your milk pitcher or whatever. Still, if there were a pulse only doserless mini available for the same cost as a regular mini, I would struggle to see how spending more on the mini-E was worthwhile.
(3) I guess that you could use a timer to grind slightly more than you need; doesn't strike me as especially helpful, but if you have a grinder with a timer and without a pulse function, you might need to do that.
As for clumps, distribution, complicated tamping techniques, etc, I think that the best way to go about working out how much to worry about them is to make a shot without going to any particular trouble, then add one bit back into your routine at a time and work out whether or not anything that you do actually improves your shots. If you don't follow this methodology, you might well end up doing everything that everyone writes that you ought on the internet writes is necessary when that time could be better spent enjoying your coffee or cleaning up your work station. For example, people have been oohing and aahing over how no distribution is necessary with the Anfim doser. But was it ever really necessary with the other grinders that they were using? I remember doing some work before WBC 2006 to see what elements we could cut out of our representative's routine to save some time and pulling excellent shots by doing nothing more than striking off and tamping once. So I ask this - are the clumps that you worry about actually that much of a problem? I mean, they're going to get hit by a tamper and then 9 bar of pressure!
I have a dosered Kony at home and before that I had a Super Jolly, so perhaps I can be of some assistance with your grinding technique. At the moment, I tend to eyeball the amount of coffee that I am grinding as it accumulates in the doser. Roughly two and a half sections full will give me an underdose for my double basket, then I can grind a bit more to top up. My Kony is glacially slow, so I tend to sweep up my area, scrub the group or do a cooling flush whilst grinding the bulk of what I need for my shot. I don't see any value in standing there and thwacking the dosing lever constantly, though such a technique would probably also help to avoid over grinding.
I don't put much effort into breaking up clumps; I don't get a perfect puck, but I don't get huge clumps either. Some time ago, I put a few wires across the exit chute from the dosing chamber as
Andy S cleverly suggested. I can't remember if it really did much to break up clumps (it might well have), but it didn't hurt and it doesn't require more time when I'm around the espresso machine. I think that that mod did help the coffee to fall down in more of a straight line without having to thwack the lever as hard to make the coffee bounce off the inside wall of the spout. My Kony doses pretty straight, but my work area still gets messy. This is not because of the doser, it is simply because I tend to dose up to a bit of a mound and strike off and at that dose level, there will be mess with any grinder. At one of the cafes that I formerly worked for, they are using 3x baskets for all shots and dosing them right down (ie. no rapping to settle), which keeps everything clean and consistent. My Kony's doser is still pretty messy, so I might do the tape mod. That said, my Kony is on loan, so I ought to work out when it is going back and maybe pick up a Mini E to replace it.
Hope that helps, and I would be very interested to know how often people make adjustments to their grind, their dose and their timer settings at home if they use a timer,
Luca
