by aindfan on Thu Jul 02, 2009 3:31 pm
Hello everyone,
I occasionally use this as an easy clean of one tiny part of the grind path. I dial the SJ burrs down to their zero point (the chirping) for just a moment; all it takes is a quick touch. Once I return to my espresso (or, right now, Chemex) setting (or get within the ballpark), and once I have backed off of the zero setting, I no longer hear the lighter chirp (not the burrs touching, just the squeak from a few remaining particles gumming up the grind path a bit) until the next time I grind.
(I am realizing now that this method is more feasible for a drip or french press grind where the grind setting accuracy is not as critical.)
Is this a method that anyone uses to clean out that space (between burr disassemblies)?
Note: "Don't be lazy and just take the burrs apart" is an acceptable, even encouraged, response to this post.
Dan Fainstein
LMWDP #203
